intake manifold question
Old May 15, 2006 | 01:58 PM
rice_patrol's Avatar
Default intake manifold question
i heard that the ex intake manifold is good. Is it true? Might be buying one to replace my y7 manifold. Also would it be that difficult to install? well thanks.
Old May 15, 2006 | 02:47 PM
Street Sniper's Avatar
Default RE: intake manifold question
Yeah, the 6th gen Ex mani is the best OEM one. Should be a good upgrade for you. Install should take about an hour depending. Make sure to label everything you disconnect.
Old May 15, 2006 | 04:52 PM
riceburner700's Avatar
taking pictures every angle you can wouldnt hurt either!!!!
Old May 15, 2006 | 06:35 PM
Nail I3unny's Avatar
you need a diff. intake.
Old May 16, 2006 | 07:59 AM
yeah i know i need a diff. intake. Would installation be straight forward or be hard. New gaskets?
Old May 16, 2006 | 11:21 AM
i would get new gaskets and get the throttle body from the ex as well because i dont think yours would bolt up to the ex manifold... but get a hondata intake manifold gasket as well.... they are well worth the money i here
Old May 16, 2006 | 01:37 PM
ill definetly look into that gasket. Thanks for pointing that out. Well i gotta save up for that manifold now. Damm work place only giving me >10 hours per week now.
Old May 16, 2006 | 01:43 PM
one other thing, i was reading somewhere that the ex auto intakemanifold is better than the manual. Is that true? or does it really make that much of a difference. Well thats just another questions. thanks.
Old May 16, 2006 | 03:50 PM
all honda throttle bodies are the same. you dont need the throttle body...but its less of a hassle.
get new gaskets. its always a good idea to replace them when you can.
installation shoudl be pretty straightforeward. one problem i know ppl do encounter is where to put the sensors. just mark and label them if you dont think you could keep track of what goes where.
Old May 16, 2006 | 05:07 PM
not all throttle bodys are the same. my cx throttle body isnt even close to linning up with the d16z6 intake manifold that i just got... plus the y7 is top mounted if that makes sense and the y8 is side mounted. i would recommend the y8 throttle body to get the true performance out of the vtec intake manifold...plus the y8 throttle body is bigger
cali1114
Oct 20, 2007 11:20 AM
88hondacivic
Oct 5, 2007 09:23 AM
psychojetpilot
Jun 16, 2007 01:15 PM
Hot94vtec
Aug 26, 2006 12:54 AM
pamitar101
Apr 30, 2006 11:08 PM
