My exhaust sounds bad
Old Jul 29, 2005 | 03:43 PM
Belmont's Avatar
Default My exhaust sounds bad
I have the stock exhaust on my civic and it rattles bad when i rev it. It sound like the rattles are coming from the front of the car.. is this something to bitch about to the dealership or is it common??
Old Jul 29, 2005 | 03:45 PM
Street Sniper's Avatar
Default RE: My exhaust sounds bad
Someone else just asked about this last week and I believe the problem was a loose heat sheild.
Old Jul 29, 2005 | 04:35 PM
carlover's Avatar
i had a geo once, yes a geo. and i heard a rattling noise but that was b/c there was a chipped area in the header
Old Jul 30, 2005 | 05:37 PM
StifflersMom's Avatar
Cat Fuсker
My rattling was from the cat converter's heatshield...welds broke..
Old Jul 30, 2005 | 06:36 PM
Remmy's Avatar
I had the same problem. It turned out to be two things:
Ok, I couldnt find it so ill say it again (if any of you do ill make it a sticky), It is either your heat shield under your manifold or it is the heat sheild on the muffler, they tend to rust at times and all you need is a plumbers bracket to tighten it up. You could also completly remove it... it wouldnt do any thing to my knowledge. Does any body reject?
Old Jul 30, 2005 | 11:43 PM
mxs's Avatar
mxs
ORIGINAL: remington870_20ga
I have no manifold heat shield anymore (rattled off about 3 months ago) and I also have no catalytic converter cover (the bottom half rusted off a year ago) and everything seems to be okay... my entire car has not melted due to lack of heat shields
Old Jul 30, 2005 | 11:50 PM
Cat Fuсker
My shifter gets warm...that's about all that happened after I removed the heatshield
Old Jul 31, 2005 | 12:20 AM
maachan513's Avatar
My 90 hatch back gets hot inside, too. May be heat shield on exhausts pipe are gone. I have to check it out. Or may be not having carpet is a reason for being hot. mmmm
Old Jul 31, 2005 | 12:33 AM
Vovka86's Avatar
Well if it is 05civ like your username states than go to the dealer and have them figure out what the hell is wrong.
Old Jul 31, 2005 | 04:12 PM
Belmont's Avatar
yea good call. its still under warranty for a long time so i mine as well take it in
