Need help with SRI installation.
Here are the intructions for my secret weapon intake. There are a few things Im not sure about. One is the coolant transfer/ PVC hardline (step 2) and the OEM AIT sensor (step 4). If anyone doesnt mind, could you please read over the instructions and these parts to help explain to me how to install this? Thanks, here are some pics.
http://img.photobucket.com/albums/v3...structions.jpg http://img.photobucket.com/albums/v3...32/intake3.jpg http://img.photobucket.com/albums/v3...32/intake2.jpg http://img.photobucket.com/albums/v3...32/intake4.jpg |
RE: Need help with SRI installation.
forgive my elite paint skills but it looks to me like the part circled in red is your "hard line" and the part in yellow looks like your IAT. I however am a n00b at this. I just installed an SRI on my EX yesterday and it wasn't too bad. The holes in the SRI pretty much lined up with the stuff that I removed from the stock intake tube, but your stock airbox layout looks quite a bit different than mine.
Any more knowledgeable guys around here should either back me up or shoot me down [8D] [IMG]local://upfiles/4809/99FB97DAFF4B40DCA052DA39FC288654.jpg[/IMG] |
Which is the pvc hardline and which is the coolant transfer. The item circled in red has two running together. One on top and another below it. Is the coolant transfer the bottom one and the pvc the top one? Thanks.
You should have gotten a little tube with your intake. You take the stock tube off that goes to the airbox and put the new one on and connect it to the new intake (red). The Air sensor should have a nice little plugin spot and as you see in my pic, its a little stretched over behind the tube in the pic (yellow).
[IMG]local://upfiles/1537/0CB7B6E3742D4A49B4DD85FDB47689CC.jpg[/IMG] |
a little scratched up? ;)
Would be a lot easier if the instructions had pictures! :D
I need help with step 9. It saying to cut a 1.5" portion of the hose and attach it to the larger port. Well problem is, it doesnt seem to fit over the port?[&o] Any suggestions, what am I doing wrong? Heres a few pics. Thanks.
http://img.photobucket.com/albums/v3.../intakekit.jpg http://img.photobucket.com/albums/v3...intakekit1.jpg |
You need to stretch and wedge and wriggle that sucker onto there. THat way it will stay in place. :)
And I dont see why you would need to cut any of the hose. |
are those two hoses the same diameter?
Yes.
