New magnaflow catback hangs to low to the ground!
Old Sep 11, 2006 | 01:03 AM
txedomask433's Avatar
Default New magnaflow catback hangs to low to the ground!
I Just installed a magnaflow catback system to my 99 civic sedan and the whole center section hangs to low to the ground. I bolted everything tight and secure, but it still hangs low. Is this a common problem for people who installed these ? What can I do to fix the situation.
Old Sep 11, 2006 | 01:24 AM
neon3kgt's Avatar
Default RE: New magnaflow catback hangs to low to the ground!
i have the same problem. what i did was use a pole jack to keep it agenst the body when i tightened it, and kept the clamp tucked up near the body so it wouldnt catch on the ground.
Old Sep 11, 2006 | 07:23 PM
CivicDrifter's Avatar
WELL IM SURPRISED SUM1 HAS A MAGNAFLOW OTHER THAN ME.THE BEST THING TO DO FOR UR CAT IS REPLACE IT WITH TEST PIPE INSTEAD OF CAT. CONV. IT GIVES MORE POWER N A LIL MORE NOISE.ULL LIKE IT BUT U MUST PUT THE ORIGINAL CAT. CONV. WHEN UR GOING TO EMISSION OR U WILL FAIL!!!!!!!!!!!!!!!!1
Old Sep 11, 2006 | 07:52 PM
fglaustin's Avatar
that emissions does come into play - sounds like a lot of work.
(please, take it easy with the caps - like shouting )
Old Sep 12, 2006 | 02:21 AM
baker's Avatar
nvm
Old Sep 12, 2006 | 07:14 PM
smit3413's Avatar
ORIGINAL: CivicDrifter
Most people on this site have magnaflows. And unless you want a cheap sound w/ your magnaflow, don't put a test pipe in place of the cat.
elnitrozo
Jan 16, 2011 06:14 AM
leco516
Nov 21, 2005 01:57 PM
Pete
Nov 9, 2005 09:40 AM
Margraf Racing
Jul 20, 2005 10:53 AM
green98lxsedan
Mar 29, 2005 01:46 PM
