O2 Removal
Old Apr 1, 2007 | 11:52 AM
rice99ex's Avatar
From: Utica, NY (home of The Saranac Brewing Co.) :)
Default O2 Removal
What would be the best way to remove the O2 sensor, if possible i would like to remove the wiring and take it off while im not on my back, would i cut the wire to do this, and i do then what would be the best way to connect it back. (First Header Replacement for me)
Old Apr 1, 2007 | 12:02 PM
FlipHKD720's Avatar
Default RE: O2 Removal
theres a harness in the engine bay, unclip that harness. Then go to the sensor itself and using an open wrench, just unscrew it. Simple at that, no cutting of wires.
Old Apr 1, 2007 | 01:35 PM
^ whatFlip said
it's easiest if the header is off the car before you remove the o2 sensor (you'll have to unplug the sensor before you remove it). I think the wrench size is like 20mm or something.
Old Apr 1, 2007 | 02:16 PM
rice99ex's Avatar
k , i got the header off, i heard that there is a special O2 sensor removing socket, how much easier would that make the removal?
Old Jun 25, 2007 | 08:52 AM
ericchile's Avatar
Same question... can't get the o2 sensor off with a normal 24 mm open socket...
Old Jun 25, 2007 | 09:44 AM
cderalow's Avatar
the socket does make it vaguely easier (at least you can use an impact or air ratchet), but if it's fused in there and you can't get it loose... it's pretty much there for life
niteryder
Jan 7, 2005 12:22 AM
me2
Dec 11, 2004 08:17 AM
spevie
Nov 5, 2004 09:31 AM
dmsteele92831
Oct 8, 2004 07:25 PM
pingu
Jul 23, 2004 05:29 PM
