O2 Sensor removal????
Old Mar 30, 2008 | 10:42 PM
z_dizzlemang's Avatar
Default O2 Sensor removal????
i have a 94 civic with a D16, i have a new header on the way, and will be installing myself, is a O2 sensor tool needed, or will a wreanch work?
Old Mar 30, 2008 | 10:44 PM
Hailchristian's Avatar
Default RE: O2 Sensor removal????
you will need a pretty long socket...if you don't have one long enough....you will need the tool
or if you will be replacing it you could just break it off..that's what i did.
Old Mar 31, 2008 | 12:58 AM
alecrust's Avatar
I highly doubt you will need a specialised tool. Mine came out fine with just a spanner on my 98.
Old Apr 3, 2008 | 09:55 AM
point break 92's Avatar
play it safe and smart, get the special tool, it's 5 bucks it's just a socket you add on to your wrench. do it !!!!
Old Apr 3, 2008 | 10:01 AM
alecrust's Avatar
I diasagree. It's a standard nut, and usually easily accessible. Only get the speacial tool if you are having trouble with just a spanner.
Old Apr 3, 2008 | 10:23 AM
T3rry's Avatar
Member
the only thing with the "special tool" is it's a socket with a hole down the side to accomidate for the wires, use a wrench, or if you dont care about the sensor, snip the wire and use a normal deep socket.
Old Apr 3, 2008 | 12:29 PM
FlipHKD720's Avatar
unclip the harness, use an open ended wrench and you'll be fine. Just dont use any lubricant to remove the sensor if its still working properly because the lubricant could damage the sensor.
Old Apr 3, 2008 | 02:14 PM
importcivicus's Avatar
ORIGINAL: FlipHKD720
Follow flips advice. There is nothing wrong with it. This is the far best one to go with. The wrench you need should be a 21mm. Use the closed end first after disconnecting the wiring harness off first. Slip the wires through and on the nut then take off. Its that simple.
Old Apr 4, 2008 | 05:57 PM
koots's Avatar
I took all of mine off with a wrench when i put my header on. It was fairly easy if there is nothing seized on it. don't let all the special tools fool you, they are not necessary but they do make things a little easier.
RPFranks
Sep 23, 2013 05:26 AM
EightyNineDX
Dec 5, 2012 04:06 AM
drbyers
Feb 28, 2011 06:38 PM
vtec02
May 9, 2007 05:17 AM
00sithrottle
May 12, 2005 10:25 AM
