skunnk 2 mani
Old 12-17-2006, 02:00 PM
Default skunnk 2 mani
just got my skunk 2 mani and installing it in my 00 si and and having trouble with one of the instructions....it says in the 99-00 si the EVAP purge control solenoid valve hose fitting will be relocated... to where the IAT sensor would usually be plugged into
Old 12-17-2006, 07:05 PM
riceburner700's Avatar
Default RE: skunnk 2 mani
the iac valve is on the bacl of the manifold closes to the firewall
Old 12-18-2006, 12:09 PM
so i can just T fit from the other vaccum source to the EVAP hose?
Old 12-18-2006, 12:16 PM
Yea, that will work. Do you have some pics? Are you sure there is no nipple for another hose?
Old 12-18-2006, 02:14 PM
yea ill get some up yea im positive there is no unused nipple for it but ill show ya just so u can see what im talking about...i read that one guy just used a T fit to do it ...aight thanks pics will be up in a bit
Old 12-19-2006, 11:56 AM
Member
I have an 00 si, let me know how it runs
What upgrades do u have?
Old 12-19-2006, 07:48 PM
Ok well the one circled in red can i T tap that one for the other hose comming from the EVAP...the hose i would be T fitting goes down into some black thing not sure what it was....in the blue i think i would have to cover this because it is for the intake air temp sensor somthing that dosent go there on my model cuse its located on the intake pipe let me know thanks
Old 12-19-2006, 07:50 PM
pic
[IMG]local://upfiles/11491/D6F458C958194BBAA82D50E42F31CD89.jpg[/IMG]
Old 12-20-2006, 09:40 AM
the circled red one is your pcv hose, the evap should be on the back right of that pic on the corner, if you are relocating the hose for the evap then were you circled the red, the next brass fitting to the right of it goes to your pfr just tap into that.
the blue square you have highlied looks like the intake manifold tempurature sensor
Old 12-20-2006, 03:04 PM
a little confused sorry...i have one hose left over that connects to a black cylindrical shape in the back right close to my battery on the fire wall...where does this hose go...if it has to be T fitted which hose do i tap
FlipHKD720
09-21-2006 09:29 AM
nightrider46
08-23-2005 03:42 PM
LEVIII
08-07-2005 07:27 PM
1SickEG6
07-03-2005 12:40 AM
KScivic
04-29-2005 08:08 AM
Quick Reply: skunnk 2 mani
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
