sri picks
you don't have that many options... only ebay; injen;simota;aem;k&n;and a few others....
they all perform about the same, so just consider what your budget is:
from cheapest to expensive
ebay - simota - k&N - injen - aem
read the intake faq sticked; you'll get a thing or two from it
it's all about what quality you want and how much you're willing to spend. i personally don't like parts that are cheap and don't fit right, so i like the aem and injen intakes because they're usually a perfect fit. but you'll probably see the same 'gain' as a higher priced unit with a cheapo from ebay perhaps with a quality filter. plus the higher end intakes such as aem are sprayed with a coat to prevent heat soak, therefore cooling things down, even if it's aluminum which transfers heat more efficiently than the oem induction system.
Steve925
Jun 27, 2010 03:21 PM
snaowke
Oct 20, 2008 03:47 AM
WrongfulWright
May 8, 2005 08:21 AM
