Throttle body size for heavy modded car
Hey guys I know its been a while, college has been taking up all of my time. Also I haven't had money so no mods. But Christmas is coming, so I'm looking into throttle bodies. I can get a 68 mm for fairly cheap. So If I could go that big I'd be happy. Let me know what size you think. Also I have Crower 402s and a header on the way. so keep that in mind.
~Engine~ JE 12.7:1 Pistons Eagle H rods ACL bearings bored out to 82mm type r water pump type r oil pump Lightened and balanced crank blox intake mani blox cam gears Bosch Platinum plus spark plugs Resurfaced head Complete valve job CTR crank pulley GS-R timing belt Place Racing motor mounts 88-91 Sir rear bracket ARP Headstuds d16 throttle body Aem Hybrid CAI APEXi WS2 Cat-Back Exhaust ~Trans~ Fidanza 7.5 lb Flywheel ACT heavy duty clutch Innovative Mounts Custom length B-series Shift-Linkage da clutch cable ~Electronics~ Swap Shop Racing Obd-0 to Obd-1 Harness Obd-1 P75 Tuned on chrome ~Cooling~ 12" slim fan Mishimoto Aluminum Radiator ~Fuel~ Benen Fuel rail Precision 880cc injectors Low Impedance blox fp gauge Walbro 255 LPH-HP Fuel Pump blox fuel pressure regulator |
Nice to see you back on the forums, john :D
Anyway, I really see no reason you couldn't step up to a 68mm TB. I mean, you have an intake, intake manifold, cams and a header on the way, raised CR, and a full cat-back. At this point, I'd say the d16 throttle body could definitely be a restriction in the system. |
Ya I kinda ran out of money at the end of the build, but someone told me I couldn't go bigger than 65 so I'm extremely confused. But ya hopefully after this, header, cam and nos the car will dominate...
