Go Back  HondaCivicForum.com > Civic Style > Header, Intake, & Exhaust
Reload this Page >
Why you don't get any fuel mileage improvement from performance mods
Old 02-07-2007, 11:00 PM
Default Why you don't get any fuel mileage improvement from performance mods
It’s been a while since I promised to write this up, and I’ve been working on this really hard. I wrote several drafts and discarded them cause they were too detailed and complicated, so one would get lost in details and miss the big picture. The one here I believe has the right level of detail, and if anybody needs more, I will gladly provide.
A common assumption among car enthusiasts is that if one adds some device to the engine that gives him extra say 10% power, his car will consume 10% less fuel if he does not use the extra power. Seems logical, yes? Would have been, if performance mods were increasing the amount of work produced per unit of fuel burnt. But they don’t. Not to any noticeable degree.
What they essentially do, they allow engine to burn 10% more air/fuel mixture. All of them, be it I/H/E or any of the chargers. Intake allows more air to be sucked in on the full throttle, headers and exhaust reduce the amount of exhaust gases left in the cylinder on the full throttle and thus allow more air in, and chargers just plainly push air…They do not increase the amount of work produced by any single unit of fuel.
Another argument can be made that stock intake and exhaust are just too restrictive and thus consume significant amount of engine power to suck air in and expel gases out. This is definitely true, but performance mods noticeably ease those restrictions only for high rpm full throttle and close to this. Under normal driving conditions pumping losses on partially closed throttle are way higher than all other pumping losses combined. And this is how we actually can regulate how much power engine is producing. Remember, on idle ALL engine power goes to offset pumping and mechanical losses.
Now, why I was telling turbo may give you better fuel mileage? Because to compress the air turbo uses the part of fuel energy otherwise wasted, hence it produces more amount of work per the fuel unit burnt. But, the way you guys do turbos, you will never see any fuel mileage gain. Riching it out and retarding ignition timing hurt efficiency badly.
That’s pretty much it, from automotive engineer point of view.[8D]
Old 02-07-2007, 11:42 PM
Default RE: Why you don't get any fuel mileage improvement from performance mods
[sm=smiley12.gif] [sm=ummmmokay.gif] [sm=why.gif]
Old 02-07-2007, 11:45 PM
werd, homey.
Old 02-07-2007, 11:59 PM
ORIGINAL: Misha
.......[8D]
But if 10% more air/fuel mixturecomes in....science states that some finite amount of energy will be created by combusting it...there by increasing the amount of power produced. I'm guessing most people believe that having that extra power (call it horse power) will allow them to reach cruising speed faster or with less throttle...there by saving gas.
Iof course am always testing the coeffiecent of friction of clutch to flywheel to tranny to rubber on the pavement. I got my I/H/E so I could pass cars going up inclines without having to downshift. Fuel savings??? Mileage??? thats just the icing on the cake.
Old 02-08-2007, 12:41 AM
ORIGINAL: Dogmeat
Itcomes inatfull throttle and high rpms. It does notcome atpartial throttle. The only way I can imagine some minuscule (still way below measuring error) fuel economy is if one always accelerates at full throttle.
Old 02-08-2007, 01:53 AM
Marty's Avatar
Sorry but your wrong, mods can save fuel milage just because all of them dont and/or all brands dont does not mean it is not there. You can de-cat a exhaust and run from 1.75 to 2.0 inch diameter, replace the stock air filter with a K & N drop in, lower your car to reduce drag, tune it for conservative objectives, run a hotter burning ignition setup, etc, etc. A big milage saver for civic owners but they rarely take advantage of it is the transmission they run. for D series people generally a 96-00 dx/lx/cx Y7 transmission will yeild the best mpg, for B series people generally a 95-01 Integra RS/LS transmission will yeild the best results, for H series use a 96-00 accord LX/DX F22 transmission, and for K series people use a 2WD crv/accord transmission(K24).
It can be done, has been done, it's just when you get right down to it people will never take advantage of it because everyone mods their cars for performance other than milage. Moral of the story, dont bitch about gas milage if you are modding your car period.
Old 02-08-2007, 02:32 AM
Absolutely agree on lowering and transmission, and I did not mean those - I was talking about engine mods, specifically I/H/E and turbo- and super- chargers.
Ignition - not on modern cars. Itdefinitelycan helpon your Impala though.
Tuning for conservative objectives - of course, no question about that.
Cat - well, one might want to remove it and then tune engine to run lean on partial throttle - will work, but at the expense of pollution and legality.
Air filter and exhaust diameter- sorry, I just wrote why those will not work...
Old 02-08-2007, 07:41 AM
I’m going to throw in the mechanical engineers POV on this topic. Any I/H/E will in some effect increase horsepower. Lets say you take a 100 hp car and with mods take it to 110 hp. Purely hypothetical. So a common thought would be if my car used to do 60 mph at 4k rpm, then with more hp (and torque) I will be doing 60 mph at 3k rpm. Again all those numbers are purely made up for the example. Unless gearing was changed, this of course is WRONG. For the most part a car, in the same road conditions will do the same speed at a set rpm and gear whether the engine is putting out 100 or 300 hp. Honda spends a lot of time making an engine that performs efficiently at a given air to fuel ratio (AFR). This number is for the most part “constant” when the engine is at operating temperature. When it is starting and the engine is cold, the mixture is rich. This is why you use more fuel when the engine is cold. So what I’m trying to say is this. All of those modifications essentially attempt to do the same thing; move air easier and more effectively. The advantage to this is the more air and fuel you have inside your engine, the more power you are producing. This is what a turbo does. But the more air the car has inside the engine, the more fuel the car will be pumping into the cylinder to preserve that AFR. When you put an I/H/E you are making your car more efficient. But in this case efficient does not mean better gas mileage, it means more power produced per constant volume size of an engine cylinder. A combustion engine is essentially an air pump. All an I/H/E does is make the engine breath better, both intake and exhaust end, which essentially increases air flow, which creates more hp. But to maintain the constant AFR, more fuel needs to be spent in the process. If you want to increase gas mileage, lowering the cars weight and minimizing drag is the best bet. Both will make the engine work less which will decrease fuel consumption. An I/H/E will make the engine breath better, but won’t increase gas mileage.
Old 02-08-2007, 08:46 AM
ORIGINAL: Misha
I'd have to argue the intake one, or at least the air filter part from personal experience
my car is entirely stock, with the exception of a K&N filter, and I had the car for well over a year before I got the K&N
I remember the best mileage I got making a long distance haul (CT to VA) was around 32mpg, was in the heat of summer, highway cruising at around 77-80mph the whole way (yay jersey turnpike) with the stock filter (2 years ago)
same trip in march doing the same speed, i got around 28mpg (it was freaking cold) (2 years ago)
same route, and trip in heat of summer again (last year), with the k&n, i managed 36mpg (the record for my car), again, same driving habits, same route, even almost the exact same amount of time (it varied by less than 5 minutes because there was a line to take a **** at the rest stop)
when i made the trip in march again, i got around 29mpg instead of 28 (last year).
whenever I make the trip, I fill up at the same gas station (on both ends), and stop at the same rest stop (pitcher on the way down, stockton on the way up), i always fill up with low test (from shell or exxon), and I always get my oil changed the day before coming down.
there were no changes in weight (afterall, i've weighed about 170-175lbs for years), and generally no changes in traffic (there's always the backup on the jersey turnpike @ noon, and DC beltway @ 3pm)
this year when i made it, with a car full of stuff (i moved down permanently), I managed 32mpg (figure with an extra 300-400 lbs) coming down
my driving habits have remained the same for the duration of driving my car (heavy on the throttle to merge, maintain pedal to keep speed steady for cruising, no cruise sucks)
I always drive with my windows down completely with the weather over 70, and about halfway in the 55-70 range, and closed lower than 55
I never run my AC while driving long distance, and I'm pretty good about my consistency in patterns
oil changes every 3000, tires rotated every 6000, and tire pressures checked weekly
Old 02-08-2007, 09:22 AM
I drive the same roads everyday and each time I calculate mileage it comes out different. There are a lot of deciding factors that come into play with that calculation. But you probably did. Only reason I can think of is with more air available at any given interval of time, your car can compensate quicker with less lag to either lean/rich your mixture.
Quick Reply: Why you don't get any fuel mileage improvement from performance mods
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
