would this exhaust fit my car??
2 Attachment(s)
Hi guys,
I have a 2004 Civic EX. I was browsing around on craigslist when I saw an exhaust for sale. It's a performance exhaust for a 2004-2005 civic SI. I was told that the SI is shorter then the EX and that this exhaust may not fit. Does anybody know 100% if it will fit or not? Thanks a lot! |
Compare part numbers from Honda. However, I seriously doubt it will fit seeing as the Hatchback exhausts are usually shorter than the coupe/sedan counterparts.
is that a hatchback exhaust? i thought all Si's were coupe. my car is a coupe
I could be wrong on it, but it does look like a hatch exhaust for some reason. The fact you were stating the seller was mentioning it may be shorter than what you need made me assume it was a hatch since the hatch exhaust systems are slightly shorter than coupe/sedan on 92-00 civics.
I would ask the seller if it came off a coupe/sedan or hatch. If you are from Canada, the Civic SI is equivalent to the USDM Civic EX, which would be a coupe or sedan. 02-05 Civic SI's in the US came as a hatchback only and equipped with a K series motor. |
The 7th gen Si only came in hatchback form. So this hatchback exhaust will not fit your coupe.
