another DIY led glow bottle cup holder ;)
11 Attachment(s)
ok ill try to keep it quick and simple WHICH IS ALREADY IS!!!!! ;)
used 10 3mm prewired leds from http://www.oznium.com/prewired-leds and only 2 sticks and a hot glue gun. available at Wal-Mart. and a dremel or just a hand held drill, I used a little dremel with a small drill bit which was a PERFECT fit for these 3mm leds! first pull your center console trim cover off and remove the cup holder from the car. then just a few marks where you want the leds. I suggest towards the shifter... that way the leds are hidden when not light and when light you cannot see them directly! Attachment 36077 and find a drill size that will fit the head of the led thru it BUT not the little bottom of the led! that way it will not stick thru the plastic much. it makes a nice guide and dept control! Attachment 36078 Attachment 36079 with with the prewired leds gently bend the head of the leds to a 90degree angle and simply poke the led into the hole, and then use the hot glue gun on each led backside to the cup holder. do no more than 3leds at a time and hold them and blowing on them helps as well to cool the hot glue so the leds are held firmly before ya let go. Attachment 36080 THEN after all leds are initially glued in place.... put more hot glue further back. which will just help the wires to be held firmer so they wont come loose and fall out after some road vibrations. Attachment 36081 then simply twist all the red-positive wires together...... and then same with the black-negatives. and simply wire them up to your desired switch. WHICH you should remember to ALWAYS use a inline fuse! no one likes a car fire from a shorted out wire! Attachment 36082 and then simply reinstall and ENJOY...... Attachment 36083 Attachment 36084 Attachment 36085 Attachment 36086 this picture is it on my dresser with no bottles in the cup holder... really bright. Attachment 36087 and blue does work the best with my favorite Gatorade... or orange for your favorite orange Gatorade...LOL blabla bla to your drink of choice! and if you REALY want to you cup holder changeable... just drill more holes and different color leds of your choice with more switches and select your own mood glowing THE END I know it sounds like a lot........ BUT ITS REALY QUITE SIMPLE though this is another project which id like to TRY and make.... same leds and stuff BUT with some different wiring which I still need to figure out... BUT i think if i used a small capacitor and a old school car flasher unit i can get a cool flash/fade trick ;) http://www.youtube.com/watch?v=kd_qbQHao9I this is just with my home 110 to 12volt being unplugged and plugged back in quickly. LOL but it was enough to really get me thinking of a sweet custom idea! after i figure out how to wire it up like this i will install it in my car! i bought this other cup holder off eBay so i could do this in my own time. which i FINALY decided to do tonight! HOPE YOU ENJOY......... |
RE: another DIY led glow bottle cup holder ;)
good job on the install. i would do it to mine but i hardly ever put drinks there.
thanks.... well its more for a show or night time cruisen ;) most the time i got wendys cups in thier or Mcds cup in thier. LMFAO but ill always carry some gatorades in my car now ;) LOL
Nice! that looks so sick. I would keep a drink there just to show it off. If I had cup holders I would do somthing like that, I think I would just use 1 led for each side just to add a effect.
1 Attachment(s)
Attachment 36076
well with 1 led for each it wouldnt be a even glow.... i thought about just using 8 leds BUT the more leds the more even the glow is so i said why not use all of them :D i also thought about doing it in the rear side pockets..... ;) might just have to find a smaller bottle to fit.LOL |
this is a killer idea. my pop-up cup holders arent so cool any more
cool idea
but my car has the pop up cup holder ;( |
it will work in either of them....... and i believe these cup holders are also interchangable....
same idea on ANY vehicle..... ive wasnted to do this to my truck for along time BUT just never did it.... :( its really easy to do! or if you want to be even cheaper you can just use some regular leds and have fun soldering the resistors and wires together.... :( which can be a PITA after so many leds! |
man that looks SOOOO sick! i would put gatorade in my cupholder just to see how cool it glows like that. awesome dyi dude thats sooo sweet il probly do it sometime :)
looks pretty good, not big into neons in the car or anything but good idea.
i want to see a picture of this pop up cupholder |
| All times are GMT -8. The time now is 11:52 PM. |
