brakes?
can you use 96 integra rear disc brakes to put on a civic or would it be a hassle to do so the question is integra discs or find a aftermarket set?????????????
No aftermarket set-ups to my knowledge. All of the rear discs you see came from a 90-01 Integra, a 92-95 Civic (SI, or an EX which came with the ABS option), or a 99-00 Civic SI.
You need the 40/40 prop valve (came standard in EKs FYI), rear brake lines from a 99-00 Civic SI, e-brake cables, and new pads/rotors/rear T-arm bushings. |
Originally Posted by cvcrcr99
(Post 774721)
Yes. User title shows "Ig'nant Mod"
:D |
(Post 774728)
:D |
