Door issues
So a little while ago I took apart my driver side door to fix a problem with the window. I don't how this happened but I guess when I took it apart the clips must have broken? Because every time I tug on the door a bit too hard the door unclips from the metal frame and just kind of hangs loose only held on by the screws in the door handle and the clips closest to the mirror.
Basically is there any way to just get the clips or some other way to fix the door because it is getting really annoying. I tries some double sided sticky tape (lol) and if i slam the door real hard it it will stay for a while.
yup go to your local dealer. they are the only place that will have them and they are going to cost 2.05ish each.i think there are 8 of them but thats just a ruff estimate from what i remember seeing. the dealer will be able to tell you home many you need.
mrsuburban
Feb 11, 2007 07:43 PM
