EK Civic Si cluster
Old Apr 27, 2007 | 07:43 PM
Spark's Avatar
Default EK Civic Si cluster
I have an AT but am saving up to get a swap w/ a MT conversion....if I get a hold of a Si guage cluster, would I be able to use it with an AT or do I have to wait to get a MT?
Old Apr 27, 2007 | 07:48 PM
Mr Mobsta Man's Avatar
Default RE: EK Civic Si cluster
It will work
Old Apr 27, 2007 | 07:53 PM
Spark's Avatar
Is it straight plugn play?
Old Apr 27, 2007 | 08:54 PM
mybrokenblinker's Avatar
there are three little connectors that just plug into the unit. If you take it out, you will see how simple it is to just pull it out and plug in the new one.
Old Apr 27, 2007 | 08:56 PM
Spark's Avatar
and another question, i currently don't have a tach with the guage i have now, will the tach work when i switch it?
Old Apr 27, 2007 | 09:53 PM
mill$civic's Avatar
ORIGINAL: Spark
Im not sure about the auto the manual thing, but the tach will work. I just switched gauge clusters to one with a tach.
Old Apr 27, 2007 | 11:47 PM
BlackDX's Avatar
The cluster is plug n play, it has all the wires for the in the harness for what is or isn't there (mainly the tach). The only issue is if the SI doesn't have the auto's gear indicator than you won't be able to plug that back into the gauge when you do the swap...... I don't think it'll pose any problems since all that is there to do is light up to allow the user to know what gear they're in......
Also to keep the milage the same from the clusters all you need to do is swap the Speedometer from one to the other, there are 4 screws that bolt the speedo into the cluster but you have to take the clear lense, light bezel and gauge bezel off to get the gauge out.... it's really easy.
Old Apr 28, 2007 | 01:12 AM
Spark's Avatar
thanks for the info. but since i'm not worried about what the mileage says, it'd be ok to just plug in and go AND the tach will work right? (sorry it's just i want to be absolutly sure)
Old Apr 28, 2007 | 01:40 AM
BlackDX's Avatar
It's entirely plug n play....... if you are worried take your current cluster out and look at the plug that connects to the left side of the gauges, notice it has a light blue wire in it....... yea that's the tach signal wire.....
The mileage matters if you ever sell the car...... I personally don't wanna run any risks and it's simple operation to swap it....... that's me.
Old Apr 29, 2007 | 12:52 AM
Spark's Avatar
I plan on taking this car to the grave with me. lol. it's my baby.
addiction2bass
Interior DIYs
Sep 25, 2008 11:41 AM
1998wagonhatch
Aug 15, 2005 03:36 PM
millertime17
Jun 26, 2005 09:38 PM
specv1faster
Mar 10, 2005 06:49 AM
Wesley
Oct 12, 2004 02:25 AM
