Ex/Si gauge cluster on CX
I have a 92 Civic Hatch Cx and as most people know this is one of the models without the tach's. Instead of buying a tach and looking like all the loser with the big ones mounted on there dash...would a Ex or Si with the tach built in the cluster work if i swapped them...if so is it a hard process? I know there would be some different wiring for the tach part im sure.
if you buy an EX or SI cluster it is a direct bolt in.. nothing to modify... the only thing you may lose (if your can is an atuo) is the gear selection light up thingy... if it is auyto you know what i am talking about
nope... you car is already wired for a tach, the connectors are the exact same... you may find too that if you car doesnt have power windows or lock, if you remove the door panel everythiung is there. same goes with the cloc. all 92-95 civic's have the same wiring harness i do believe, it is just cheeper to make one harness for all cars then one for each car
1998wagonhatch
Aug 15, 2005 03:36 PM
specv1faster
Mar 10, 2005 06:49 AM
