HondaCivicForum.com
-   Inside and Out (https://www.hondacivicforum.com/forum/inside-out-9/)
-   -   Foglight Install (https://www.hondacivicforum.com/forum/inside-out-9/foglight-install-39319/)
my05civic Mar 3, 2007 11:35 AM
Foglight Install
How long does installing fog lights take? What's the hardest part of the install?
Belmont Mar 3, 2007 11:39 AM
RE: Foglight Install
It depends, I think the wiring is the hardest part.
my05civic Mar 3, 2007 11:48 AM
the wiring seems to be most of the instructions lol. does prying the center panel off make it loose in the future?
TheMoogly Mar 3, 2007 11:58 AM
In my LX the longest thing was cutting out the holes for the fog lamps and epoxying them in flush. The whole install took about 1 1/2 hours to do. I should have taken pictures... we took the whole bumper off and placed it face down on some wood horses with towels on them to protect the paint, then we used a dremel like tool to cut out the holes, then epoxied and mounted the lights to the brackets on the inside of the bumper... then did the wiring and my friend did the inside wiring and switch and stuff.
my05civic Mar 3, 2007 12:04 PM
in the instructions, it says that there are only 5 tabs where the fog lights holders are that you cut out... does it really take that long?
also, why is epoxy necessary? does it prevent water? does it matter if water gets into behind the foglights? i currently don't have epoxy so i'd have to go buy some
TheMoogly Mar 3, 2007 12:10 PM
If you're an EX your tabs should pop out... my LX's black covers are actually molded into the bumper and they needed to be cut out... the epoxy was for better hold and because the seal wasnt perfect because of the way we cut... on my bumper you could tell it is supposed to have mounting tabs but they are incomplete (probably at the factory since my LX has no fog lamp option) so we broke off other pieces of hard plastic and epoxied and screwed them together and into the holes where the inside of the bumper has. We've had TONS of rain and some snow... but it doesnt matter with moisture because you have a big opening in your lower and upper grill that lets water through and it gets on the fog lamps anyways... we were just more cautious so we used epoxy.
txedomask433 Mar 3, 2007 12:49 PM
Just remember to ground the wires to the right spots. I was going crazy for hours figuring out what I did wrong until I grounded it to the right spot.
my05civic Mar 3, 2007 12:49 PM
i have a lx 2005 sedan. you think i'll have the same issues?
TheMoogly Mar 3, 2007 03:04 PM
YEP! We got the same car!
