Headlight Restoration
6 Attachment(s)
Hi.
I saw the "headlight defogging" thread. Read it, and I have a different but similar approach. I'll include pics so you can see for yourself. First off... Be careful. Your going to be working on a clear piece of plastic. And read: Companies make head light cleaner that's a petroleum based solvent, but it doesn't work very well by itself. You really have to rub the hell out of the lens, and then your left with a shiny, pitted lens that looks like crap. Before I did this, my head lights had corroded to the point where there were deep pits in the lens. The corrosion comes off in yellow gooey sludge its nice... Anyways here's how I did it: Materials Needed: 1 Sheet 400 grit automotive sand paper ONLY 1 Sheet 600 grit 1 Sheet 1500 grit - I didn't see any but if you find anything higher then 1500, then get some. 1 Bottle detergent automotive degreaser - I used "Purple Power". It works great. DON'T use lacquer thinner...! Dish soap diluted with water will probably work too 1 Buffing wheel 1 Fine Red Rouge - I got my kit at Sears (came with 3 wheels S/M/L in size. and 3 sticks of rouge) for about $10 1 Roll paper towel 1 Bottle of Headlight lens cleaner from your local auto parts store 1 Set goggles Notes: Find some shade Read all the directions before doing this... Here is what they looked like to start with: Attachment 16576 Directions: Step 0: Tape off your hood and bumper to protect it. Step 1: Use the detergent degreaser and clean off the lenses. Step 2: Keep the lenses wet with the detergent cleaner and sand them with 400 grit sand paper. Do not dry sand the lenses - EVER...EVER!!! Don't sand hard either. Press no harder then as if you were sanding your face :) You'll build up a nice yellow/white gooey sludge, and that's what you want to work with. Clean the lenses occasionally to see any high or low spots. Eventually the the sludge will become pure white, that means you've sanded through most of the corrosion. Sand with 400 till you see consistency, and a smooth surface. If you press hard while sanding you'll put deep scratches in the lens, and you'll spend more time getting them out then if you sanded lightly from the beginning. Attachment 16577 Step 3: Repeat step 2 but with 600 grit paper Attachment 16578 Step 4: Repeat step 2 but with 1500 grip paper Attachment 16579 If you found 2000 grit then do another round of sanding. I was limited to 1500 grit :( Step 5: Get a good layer of red rouge on your polishing wheel. Then take some of the lens polish and spear it on the polishing wheel. Mix it with the rouge. You can also wipe a light layer on the head light. As soon as you hit it with a spinning polishing wheel its going to spray all over the place, so wear goggles... Use a Dremel or a high speed drill. Use the biggest polishing wheel you can. The closer the drill is to the lens the more likely you are to hit the drill on your lens. Step 6: Keep the polishing wheel wet with lens cleaner and rouge, buff until your happy with the finish. I found turning on the lights at night lets you see all the spots you missed. Attachment 16580 Attachment 16581 It made a BIG difference driving at night. Well worth it! These pics are with out wax :) Wax them to protect them, which I haven't done yet ;) Good luck! |
looks good, +1 on a good DIY write up
this should be moved to the DIY section
good job! |
