HELP!!!
If your talking about a grille, i take it you've got the EK model, i havn't ever changed a grille but if you want a new interior panel, there are quite a few on ebay, different styles, i cant tell you if they will be good quality but i know if you go to a Honda dealer they will charge you millions!!
the grill is easy to change pop your hood and look at the top of the frill there will 5 plastic screws take those out then there is one on the left and one on the right of the grill that holds the top of the bumper in place takte those out then slide your old grill out and slide the new one in
i agree with black for the most part but i think you have to pull the bumper cover off because there are about 4 or 5 screws that secure the grill to the bumper cover itself. it is easy i was ****ing around with it the other day.
step 1
step 2 there are 2 10mm under the center of the bumper ( would help if car is off the ground) remove those and finally
step 3 under each headlight there is a clip that secures the bumper to the fender (should be a bolt or a clip or something) remove and voila detached bumper
look right under the grill and you'll see the screws in question
if you need pics i'll see what i can do
step 1
pop your hood and look at the top of the grill there will 5 plastic screws take those out then there is one on the left and one on the right of the grill that holds the top of the bumper in place take those out
nah thanks i have figured out how to remove it i just want a nice replacement so it is a bit different but i cant seem to find any. is this not a popular mod for the civic? i think it would look very good with a small honda badge in the bottom right hand corner of the grill. that is what im aiming for
haha
haha
