Interior LED's installation??
Hey,
I'm trying to install interior LED and hook them up to the parking lights on a 98 civic. How do i?? like where do i find the wire? idk really... help plz? I want to do it so that the interior ones turn on with the exterior LED's. |
The easiest way is to just hook it up to a switch, but in your case, I think I have a solution from my fog light install DIY.
https://www.hondacivicforum.com/foru...1&d=1218383792 Slot 2 on the fuse block. Use a female wire connector, crimp to wire, and put it in that slot. Put your ground wire under any loose bolt you see. Any time your turn on your parking lights (and the dash lights), they'll come on. |
sick thanks.
for the female wire connector do u mean something like the yellow thing in the middle left box in this?:
http://electrical.hardwarestore.com/...it-102809.aspx |
Actually, the middle right. Red ones. If you look at the fuse box, you'll see a prong sticking out.
awesome thanks :) and ur ride would look sick if u painted ur rims black glossy
hey i was messing around with some wiring and i think i popped the fog light fuse...where is it?!?! idk how to reset\change it.
