Muffler fitment with Type R Lip??
Anyone here install the type r lip or bumper to rear on a ek hatch with a magnaflow or similar exhaust.. ?? And does anyone know if the lips cover up the exhaust cuttout on the rear bumper/? specifically just wondering if it will fit as i already had to trim my exhaust cuttout on my hatch due to adjustment from the addition of sway bar in rear.. the bracket was rubbing on the exhaust pipe.
RE: Muffler fitment with Type R Lip??
well..i can tell you that with a type R rear lip it fit around my exhust good but my muffler would rub against it, so i got different exhust hangers and dropped the back a little so it dosent rub
So you had to drop the exhaust down some in the rear? if so this would create an issue for me due to the added sway bar in rear..
Mill: the type R hatch lip is different than yours.
ORIGINAL: pWnEdU Mill: the type R hatch lip is different than yours. |
I know that i need to get a rear lip because my twin loop hangs a little low. I dont know if its because the twin loop is a mugen replica and its meant to go with a mugen lip kit or what, but it hangs a little too low for my liking right now. It doesnt look TOO bad, it looks fine from the sides, just when your behind me you can see a little too much of the muffler itself. I would rather just have the tip being shown and a little of the bottom of the muffler thats it.
I would like to know if the type R hatch rear lip would fit on a coupe... I like 'em.
sway bar runs just a bit higher than the control arm which was issues i had before installing the exhaust.. had to adust it to get it right in the middle of the opening so when i accelerate and turn it doesnt rub ..
since this wasnt completely cleared up.. i have considered replacing rear LCA's wondering if this may give more room with aftermarkets.. and if someone can correct me ,, or clarify.. arent good LCA lightweight over stock? so i would drop at least 5 lbs or more?
