one dull headlight...
One of my headlights is dark orange (on brights and dims). So i changed the bulb, no change. Checked all the fuses and they are all good.... Any ideas why my drivers side headlight is so dim, im out of ideas....
RE: one dull headlight...
Bad wiring?
I'm assuming you'd be able to tell if the headlight was fogging up? If not, then I think it could be a wiring problem as well.
The wiring is all stock and not tampered with, the plug in to the bulb looks kinda corroded tho could that be the problem? How do I clean the connector up inside? Headlights are clear not foggy..
ORIGINAL: redridinhood The wiring is all stock and not tampered with, the plug in to the bulb looks kinda corroded tho could that be the problem? How do I clean the connector up inside? Headlights are clear not foggy.. take the plug out and clean it, use a little wire brush. to scrape it off, check the inside of the female plug aswell and clean it. |
Yeah clean out those plugs...more than likely that crap is causing a poor connection thus the dull light
You can buy those plugs. I got a new set at Auto Zone for like $3. Some how my old ones were melted.
