rhino liner vs. carpet
Old Aug 9, 2009 | 08:13 AM
xsteinbachx's Avatar
Originally Posted by wisener
all i have down is floor mats i figured adding something is obviously going to add weight but there HAS to be something lighter than carpet.....but what????????????????
Learn to multi Quote and don't post 4 times in a row. It'll stop you from looking like a tool.
Old Aug 9, 2009 | 11:35 AM
mudferret's Avatar
Save Rhino lining for the interior of your favourite offroad vehicle. It's heavy, will make your interior ridiculously hot, and is expensive to do an interior unless you do it yourself, or do all the prep before you have a pro spray it.
Old Aug 9, 2009 | 12:24 PM
Shave the irregularities in the floor pan (make it perfectly smooth) and paint it the color of the car. Then get fiberglass-backed racing seats and have the fiberglass backing also painted to match the car. Cage it (also painted to match) and get 5-point harnesses, then enjoy your bada** interior. Also, the racing seats will be lighter than your factory seats, and the cage/harnesses combo will be safer than the factory belts if properly installed and used.
Old Aug 9, 2009 | 01:00 PM
Why do you think your HONDA CIVIC is going to seriosly be faster without the carpet in your car?
Old Aug 9, 2009 | 09:23 PM
wisener's Avatar
thank you sounds like a plan
Old Aug 9, 2009 | 09:27 PM
oooooH haha I doubt you will do it, but if you do I cant wait to see some pics
Old Aug 10, 2009 | 03:21 PM
Word of advice: my plans are usually ridiculously expensive. If you know someone that can do the metal fab and paint, it would be around $1,000 minimum to do what I said. If not, I don't even know where prices would begin (this is why you look for people that can hook you up at every chance you get. Connections are where it's at ).
But if you do go through with it, make sure you post pics. Also, your interior will be my favorite one ever
Also, another idea if you go through with it: Integra dash swap. It's not that hard to pull off, and it's actually not too expensive if you can find someone parting out a 94-01 integra with a good dash/center console.
Old Aug 10, 2009 | 03:54 PM
PunisherInOKC's Avatar
If your car is a daily driver, just put down some carpet. Its not that expensive and you can do it yourself.
Rhino = expensive.
Doing the sound deadening is a good idea, but not required. You can get some cheap foam from Walmart and use it. Will give you something to adhere the carpet to, and make it so you dont' feel the harsh metal all the time.
Old Aug 11, 2009 | 02:00 PM
slammedEF's Avatar
rhino if done correct is nice looking my buddy has a DA9 with rhino lined floor and its not hot inside the car. and it looks clean as hell. plus it grips even when your feet are wet.
94civichatchback
Nov 12, 2010 03:55 PM
94civichatchback
Oct 13, 2010 07:13 PM
Dontoh
Jan 26, 2010 11:09 AM
GReddy_Civic
Apr 6, 2007 07:05 PM
zdzichoo1
Dec 31, 2005 12:29 AM
