Rims
I have a 2002 Civic Lx with spoiler not many other mods yet.. i want to make the car a silver and dark blue dark blue glow inside as well as dark blue wave like decal i wanna get some cool (affordable rims) any suggestions?
for affordable rims check out wheelsnext.com tire and rim packages
free shipping, hidden balancing, and touchless mounting don't do decals, they're stupid for LEDs inside, use these: http://www.oznium.com/led-flex-strips use 4.7" under the dash (one on each side), 2.4" pointing forward under the front seats (one for each seat), and 2.4" pointing backwards under the front seats (one for each seat) wire their positive wires all into one positive wire, and run to to a switch of your choice http://www.oznium.com/switches (i like the round rocker switches, you can use a big drill bit to drill a hole in a piece of trim for the switch), and then run them to the cigarette lighter (this way if you leave the switch on the lights will turn off when you turn off the ignition) bolt the end of the ground wires from each LED strip to a good metal ground on the car. you can carefully pull other the positive and negative wires apart from each on each LED strip. if you got an LED switch, it will also need to be grounded. |
Amazing sites thanks for the links!
I agree that decals do tend to look extremely tacky, although I am one that loves the clean look.
Originally Posted by CivicLxftw
(Post 588975)
(Post 588975)
no decals
hey
dont u think that
http://img60.exs.cx/img60/6853/contstacura.jpg would look amazing on a small 2 door silver civic (the swipes)? |
it looks alright, but i truthfully thank it would look better just the solid color.
hey
dont u think that
| All times are GMT -8. The time now is 11:29 PM. |
