SMOKE HEADLIGHTS
Old Aug 7, 2005 | 04:25 PM
hondaman310's Avatar
Default SMOKE HEADLIGHTS
I wanted to know if anyone knows how i can smoke the inside of my headlights to make them have that smoked look cause i dont want to to buy lights.
Old Aug 7, 2005 | 08:18 PM
Remmy's Avatar
Default RE: SMOKE HEADLIGHTS
spray paint. I know this guy that had done them to his 99 accord and they look pretty good.
Old Aug 8, 2005 | 05:01 PM
bleedhondos's Avatar
2 options, you can open your headlights and paint the headlights or you can get transparent paint and paint the outside of the headlights. I recommend the first choice it doesnt dim your lights.
Old Aug 14, 2005 | 03:21 AM
babyamber's Avatar
first double check with your states laws. Some of them are if it wasnt factory than you cant have it. second dont use spray paint. use acrilic paint (not too much or you will need new ones) this will take some time so make sure you dont have to be anywhere for atleast 3 days. take them off. open them up (without breaking the adhesive you do you will need new light) you might have to go through the bulb insert! what you do is wet the inside of the light pur in a LITTLE im saying LITTLE here of acrilic paint (little water helps too) and shake it around. leave it on the galss for an hour, pour out the water. repeat alot. that will give the best smoke looking lights youll ever find doing it yourself that is if you do it right!. use gray pain not black baaaaaaaaad. gray can over lay with out getting darker. black cant. so try that. if that doesnt work for yea. as long as teh layers are still slightly wet yo ucan wash it out with a high power water! good luck. try it my way or not. just remember it takes alot of time it will take 3 days for one side! so if you got the time go for it.
Old Aug 14, 2005 | 08:46 PM
the 2nd option dim down your headlights
Old Aug 14, 2005 | 08:54 PM
XCM828's Avatar
Cosworth
Dec 15, 2008 05:35 AM
titoe
Apr 28, 2005 02:11 PM
titoe
Apr 26, 2005 09:17 PM
mx6s girl
Mar 28, 2005 05:26 PM
niteryder
May 29, 2004 11:35 PM
