HondaCivicForum.com
-   Inside and Out (https://www.hondacivicforum.com/forum/inside-out-9/)
-   -   Something to do with my front bumper.. (https://www.hondacivicforum.com/forum/inside-out-9/something-do-my-front-bumper-76648/)
Outlawmusician Jul 1, 2009 10:11 AM
3 Attachment(s)
Ok, well my bumper fell off lol and when I looked behind it that metal bar was only bolted on one side because what I think is my car radiator support lol idk its messed up...I have some pictures of it.
Also, zip ties...will they work for the time being until i get new clips for the bumper lol that's why the bumper fell off because it was missing the clips holding it on..but yeah
WellFedHobo Jul 1, 2009 10:22 AM
Woooooow. Looks like it got hit pretty hard. that's probably in need of a new radiator core support...
NIKE H34D Jul 1, 2009 10:23 AM
bahahaha you can bend the radiator support back into place with an upscale hammer and a little creativity :P EDIT Its done for lol you need a new radiator support... i didnt look hard enought at the pictures at first..
its definately been in a wreck and got hit on the passenger fender by the looks of it...
Outlawmusician Jul 1, 2009 10:30 AM
yeah i got it as a gift from my parents. With a new radiator support i would have to cut it off and wield it back on?
reaper2022 Jul 1, 2009 10:35 AM
not necessarily cut it off; it should just have spot-welds holding it on (probably a lot of them, too). You can get a spot weld cutter for a drill and drill out the spot welds nice and cleanly, then spot-weld the new core support back in place.
Here's what i'm talking about with the spot weld cutter:
http://www.northerntool.com/images/p.../154830_lg.jpg
Drill a 1/8" pilot hole down through the center of the spot weld, the put the needle guide down through the hole and go to town; it cuts the spot weld out perfectly (also, try not to drill a hole through the underlying metal; you just want to take the weld itself off). Then, use a chisel to separate the pieces of metal and you're done :D
Outlawmusician Jul 1, 2009 10:38 AM
ahh ok ty for that!
Sounds like I have some work to do..
Outlawmusician Jul 1, 2009 11:16 AM
ha well i've decided that my car is not worth fixing now. Just have to use it till i get a new car
NIKE H34D Jul 1, 2009 11:23 AM
? Whats wrong with the car?
Outlawmusician Jul 6, 2009 07:26 AM
The radiator support is messed up and so is the frame...
reaper2022 Jul 6, 2009 09:40 AM
Unless the frame is FUBAR, it can be pulled out by a body shop that knows what they're doing (and has a frame puller) no problem. And the radiator support would take an afternoon for a novice to fix.
