Speedhut Glo Gauges.
Old Aug 3, 2006 | 08:15 PM
Dan Sama's Avatar
Default Speedhut Glo Gauges.
I'm about to buy some, and I was just curious about you guys' experiences with them.
I'm getting them for my 97 Civic Ex, and I wanted to know how installation went, whether they plug into existing wiring, or whether there's a lot of electrical work involved, also how did you go about removing the lighting that illuminates the stock gauges.
Also, where's the ideal place to mount the dimmer switch.
http://www.speedhut.com/el_detail.as...mber=12&bhcp=1
here's a link for reference.
Any responses you guys have will be great. thanks again
Old Aug 3, 2006 | 08:34 PM
mill$civic's Avatar
Default RE: Speedhut Glo Gauges.
well..im not sure installation wise, but my buddy bought from them and he loves his, no problems at all with them, im also going to buy some soon
Old Aug 3, 2006 | 08:46 PM
Dan Sama's Avatar
another thing, does it run off the main power supply or do i need to buy batteries for them occasionally?
Old Aug 3, 2006 | 08:58 PM
BlackDX's Avatar
Thier customer service is damned good (had a guy swap his gauges for a different design due to not being able to see the silver numbers on the silver flames {bad design on his and thier part} and they did it for free). All you will have to do is splice it's power wire into the illumination wire for the gauges and you're good to go.
Get the upgraded inverter, it's worth the extra bucks and it really cleans up the install as well as makes things lots simplier (two wires and a wired glowing adjuster fob that's smaller than the ****), as well as the thing (least so they say, since I got the upgraded one I can't say if it's brighter or not) is sapposta be loads brighter as well.
Old Aug 3, 2006 | 09:07 PM
Dan Sama's Avatar
so basically its one wire you splice into the power, and is there a way to make it so i can just run off the stock brightness adjust?
also, is that the upgraded invertor that they show in the picture on their site?
Old Aug 3, 2006 | 09:48 PM
mill$civic's Avatar
ya i dont get why they dont say anything about the inverter,im going to order some, $68 for gauges and a polished aluminum bezal shipped..good deal, now i might upgrade the inverter..humm
Old Aug 3, 2006 | 11:32 PM
BlackDX's Avatar
This is thier upgraded inverter:
This is the normal inverter:
Yea you connect the positive for the inverter to the illumination wire and then leave the adjuster on the the glowing fob in the brightest setting and as long as the wire you connected it to is the one that actualy lights up the gauges than yes it will dimm like the gauges normally would.
Old Aug 4, 2006 | 12:26 PM
Dan Sama's Avatar
awesome thanks, i'm gonna order mine later this week
PonDaCivic
Apr 7, 2009 01:59 AM
lurker
Jan 4, 2005 05:01 AM
dadax2
Oct 22, 2004 09:09 PM
dadax2
Oct 22, 2004 09:08 PM
seigi
Sep 16, 2004 06:18 PM
