HondaCivicForum.com
-   Interior DIYs (https://www.hondacivicforum.com/forum/interior-diys-55/)
-   -   Acura Integra Gauge Cluster Installation (92-95 Civic) (https://www.hondacivicforum.com/forum/interior-diys-55/acura-integra-gauge-cluster-installation-92-95-civic-71092/)
danomatic93 10-29-2008 10:03 PM
38 Attachment(s)
This is a detailed DIY for installing a 94-01 Integra Cluster into a 92-95 Civic. You are more that welcome to use this as a guideline as there are many ways of displaying the cluster.
Tools/Items Used:
Knife (Small Flat Head Driver)
Masking Tape
Heat Gun
Dremel (Cutting and Sanding Bits)
Ove Glove
Safety Glasses
94-01 Integra Cluster with Pigtails (I used a 94-97 Cluster)
92-95 Civic Cluster Bezel
Acrylic (Plexiglas)
Epoxy
Flat Black Spray Paint
Sandpaper
Small piece of a paperclip
EG trip odometer stick rubber end
1” nylon sleeve with O.D. ¼” and 6-32 thread size inside
2” 6-32 threaded rod
Civic Cluster Bezel Preparation:
Let’s start by getting the Civic Cluster Bezel ready. I wanted the have a clean stock feel with these gauges, so I wanted to use a stock bezel (well, really just the frame of it.).
1. Remove the Bezel from the donor Cluster. 5 tabs, use ‘em.
Attachment 24123
2. With a knife, shove it in between the Bezel and the plastic cover. Work your way around the cover, carefully prying up the cover as you go.
Attachment 24124
Attachment 24125
3. Mask off the inside of the Bezel with tape to protect it from scratches later.
Attachment 24126
4. Get out the Dremel and cutting disc and cut it out. Leave extra material to sand down so that you don’t scar the Bezel.
Attachment 24127
Attachment 24128
WEAR SAFTEY GLASSES!!
Attachment 24129
Attachment 24130
You can see how much I left to sand here:
Attachment 24131
5. Again with the Dremel, but now with the sanding tubes. Sand it flush.
Attachment 24132
Note: I also hand sanded with 180, 360 and 600 grit sand paper after using the dremel.
Attachment 24133
6. Trim three tabs of the Bezel.
Before:
Attachment 24134
After:
Attachment 24135
7. Lightly scuff the surface with fine grit sandpaper (600+), clean with alcohol and let it dry, then paint flat black.
Integra Cluster Preparation:
Get out the Integra Cluster
Attachment 24136
1. Remove the Bezel on the Integra. Tabs and 3 screws in the back!
Attachment 24137
2. With the Bezel off, remove the clear cover and cut the Bezel with a Dremel.
Attachment 24138
Note: the Bezel is on the cluster just for the picture; do not cut with the Bezel on the cluster. You will screw up!
Attachment 24139
Note: I cut down some fins on each side.
Attachment 24140
Note: I trimmed this lower part of the Bezel to allow the Civic Bezel to sit on this Bezel more easily.
Attachment 24141
To fit the cluster into the car I had to cut down the cluster’s sides a little. Both sides were cut the same.
Attachment 24142
3. Test fit, Test fit, Test fit!!!
Attachment 24143
Stop and admire a side by side.
Attachment 24144
4. Add extra material on the upper corners of the bezel where there is a gap between the integra bezel and civic bezel.
Attachment 24145
Attachment 24146
Note: I used extra Plexiglas and epoxy then sanded it flat.
Attachment 24147
Attachment 24148
5. Lightly scuff the surface with fine grit sandpaper (600+), clean with alcohol and let it dry, then paint flat black.
It should look something like this:
Attachment 24149
6. Extending the trip odometer stick:
Random parts I used:
-a small piece of a paperclip
-EG trip odometer stick rubber end
-1” nylon sleeve with O.D. ¼” and 6-32 thread size inside
-2” 6-32 threaded rod
Attachment 24150
Attachment 24151
To do it:
a. Drill a small hole in the Integra trip stick to receive half of the length of the paperclip piece you cut. This is used allow the extension something to hold onto.
Attachment 24152
b. Epoxy the paperclip piece in place.
c. Push the EG trip end onto the threaded rod.
d. Cut down the threaded rod a little. Be sure the nylon sleeve can still thread on.
Attachment 24153
e. Now, you can epoxy the extension on OR build up the diameter of the paperclip with epoxy so that the extension slides on snugly without being permanently attached.
Custom Cluster Cover Preparation:
We want our final product to have a hole for the trip odometer reset stick to be in the right spot. Yes, you can use the stock cover BUT, you’ll have a hole in the wrong spot. So, let’s make our own cover!
Get some acrylic (Plexiglas) from your local hardware store.
Attachment 24154
1. Cut the Plexiglas to rough length. Notice that it’s flat, for now.
Attachment 24155
2. Pull out the Ove Glove and Heat Gun and begin to evenly heat the Plexiglas.
Attachment 24156
3. While heating the Plexiglas apply pressure by bending it slowly. Do this until it has the same curvature as the stock cover.
Attachment 24157
4. Cut the Plexiglas to rough shape.
5. Cut the whole for your extended trip odometer stick.
6. Remove the protective plastic on both side of the Plexiglas. TIP: if it doesn’t come off easily, soak the cover in water for 5-10 minutes.
7. Epoxy the Plexiglas cover on and trim it down if you need.
Getting the bezels together:
1. Epoxy them where you see fit.
Wiring:
Wiring charts found on Honda-Tech:
http://honda-tech.com/zerothread?id=1053318
The Final Product:
Attachment 24158
Attachment 24159
Attachment 24160
BillyB98 10-30-2008 05:58 AM
I <3 DANO! Im going to do this!!!!!
driftingfan 10-30-2008 04:55 PM
Would that work for a 97 civic? Or more work is needed?
danomatic93 10-30-2008 10:08 PM
For any EK (96-00) it would be a hell of a lot easier. You can re-pin the plugs (pigtails), the cluster fits in as is with minor modification. I don't know the specifics though, just google it.
danomatic93 12-02-2008 03:41 PM
1 Attachment(s)
Night Driving Time Lapse:
http://s106.photobucket.com/albums/m...t=MVI_0794.flv
Attachment 23437
BX_Civic 12-02-2008 05:14 PM
Nice mod and cool vid. Was that done with still pics or with a vid camera?
danomatic93 12-02-2008 06:30 PM
My digital camera doubles as a video camera and has the feature of time lapse. It's actually a big reason I bought it.
