Window Regulator Removal/Inspection/Maintenance
17 Attachment(s)
This DIY is going to show you how to access your Power Window Regulator, Motor, and other components. Honda's are well known for having window issues. Whether it be sliding off the track, not rolling up all the way to the seal, or just dying in general.
Alright, last fall I had an issue with my driver's side window, which stopped me from being able to roll the window up all the way, this is what it was doing... http://i12.photobucket.com/albums/a2...h_MOV00330.jpg Notice it goes up, then starts bouncing. Basically, it wouldn't seal and I was getting a lot of wind noise on the highway, and obviously leakage when it rained. Even if this isn't your specific issue, the process below can definitely help you. Moving on.. 1 - Pull the speaker out, then remove the door panel. There are 5 screws, and a bunch of stupid clips. -Screw #1 is in the armrest -Screw #2 is in door handle -The other three surround the speaker Attachment 36649 Attachment 36650 Attachment 36651 2 - Once you've pulled all the screws, the next step is to pull the handle and armrest housings out. BEFORE you disconnect the window buttons, get the window into a position where you can easily access the bolts holding the window to the regulator, shown below.. Attachment 36652 Straight to the right of this big opening in the door, will be a circle opening, get the window to where the bolt behind that circle is easily accessible through the hole. Attachment 36653 3 - Remove housings. It's pretty basic, just pull them out carefully as to not damage the wires behind. Unclip the connectors, and set the housings aside. Attachment 36654 Attachment 36655 3 - Next, remove the door panel. You'll have to give the door a bit of a tug to pop it loose. Don't be surprised if you break a clip or two, it happens.. I've been told you can buy them at Lowes, but you don't need all of them, so no biggie. Attachment 36656 4 - Disconnect the electrical connection that feeds the window motor. You need to be able to pull the wire connected to the window motor through, and out the door. (It'll make sense when you get there) Attachment 36657 5 - Remove the Glass. Some say you need two people for this, however I've done it three times now, by myself each time, and have not had a problem yet. Undo the two 12mm bolts holding the bottom of the glass do the regulator. Attachment 36653 Heres that little circle opening we talked about earlier. Attachment 36659 6 - Remove the glass by carefully picking it up at an angle, so that the back side comes out of the track first, then slide it out the rest of the way. Don't drop it :D Attachment 36660 7 - Now, onto removing the regulator.. There are 6 bolts holding it in, all 12mm IIRC. -Pull these two first Attachment 36661 -Then remove the four bolts in the middle of this next picture. BE CAREFUL, once you take the last one out, the whole assembly is likely to fall. Not a huge deal, but if you're regulator is in fact okay, it might not be after the fall. Attachment 36659 8 - You can fold the regulator up while its inside the door, and carefully slide it out the big opening. You'll have to maneuver around a bit to get the motor out. Attachment 36663 Okay, from here, the process is problem specific. As you can see below, I've highlighted in yellow what the problem was for me. Its a little pivot joint, that should allow the regulator to move in a scissors type fashion. Mine however, was allowing way too much side to side movement, and making the gear in the motor skip off the gear in the regulator. Attachment 36664 I thought it was the gear inside the motor, that's why you see a brand new one sitting there. Since it wasn't the problem, I returned it and picked up a new regulator from the stealership for about 70 bucks. If your problem IS the motor, then replace it with a new or refurbished one. It's pretty straight forward, the only issue is that you'll need the proper tool for the motor to regulator bolts. It looks like this.. Attachment 36665 9 - There should be three or four of them holding the regulator and motor together. Pull the motor off, attach the new motor (or in my case, put the old motor onto the new regulator), and work backwards for re-installation. That's it, enjoy your fully functional window! |
