Xenon headlight not working. Need advice
Can someone help me trouble shoot my hid trouble. I have H1 bulbs install in my 98 civic. It worked all day until I pulled into my drive way. What should I do to fix this???
lol, so you have done ZERO diagnostic work on it?
Both bulbs go out at the same time, or just one? You need to give us more info. |
What kind of system do you have? Bi-Xenons? Have you checked the headlight fuses?
Xenon bulb
This reply is for cvcrcr.. I've done diagnostic work. Test the voltage on both headlights. And when ever I change the fuse. It pops. Now what??
IIRC, the fuse continously popping means the wrong fuse is in there, or there is a short in the wiring. By no means am I good with wiring. I hate it. This is the extent of my electrical knowledge pertaining to your issue. lol
Originally Posted by MrGonzo123
(Post 781456)
-Google/Youtube how read a wiring schematic. -Buy a Multimeter. -Google/Youtube how to use a multimeter. -Test for continuity and chassis ground at the headlight wiring. ...if that's too much for you, no one here will be able to help you with your electrial woes. Good luck! |
I actualy do HID installs all the time.......but on your honda do you have the hid's wired to a harness?or are they directly connected to your stock wiring harness..?
| All times are GMT -8. The time now is 11:52 PM. |
