1997 mazda 626 check engine light
Old Sep 22, 2006 | 08:38 PM
thakid's Avatar
Default 1997 mazda 626 check engine light
i was suppose to post this a while ago. my brothers 1997 mazda 626 engine light was on for a while and no one that i knew could find out what was wrong until we too it for emissions. and the diagnostic report said
MIL engine off: PASS
MIL engine on: FAIL
DLC rampering: PASS
OBDII Communication: PASS
MIL Command Status: FAIL
Fault Codes: P0400 EGR Flow Malfunction
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
can any one help me with this and how to get it to pass emissions
Old Sep 23, 2006 | 12:50 AM
finalimpact's Avatar
Default RE: 1997 mazda 626 check engine light
replace the cat........as for the egr......sounds like it has a lift sensor, check the vacuum soleniod which supplies vacuum to the egr. also make sure the egr isnt clogged to where it cannot open. damnit and also check the vacuum lines going from the intake manifold to the egr vacuum solenoid and to the egr valve.
Old Sep 23, 2006 | 09:11 AM
AgentofDarkness's Avatar
A quick check for the EGR valve is to push the diaphragm in while the engine is idling. If the engine starts to run bad, then the EGR valve is working properly and your problem is probably caused by the EGR valve not bieng given vacuum to open.
Rool_908
Jan 3, 2012 07:03 AM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
pupun
Jun 16, 2009 07:39 PM
tork
Apr 29, 2005 12:31 AM
