2008 Nissan GTR Specs released
http://www.rsportscars.com/foto/10/gtrproto05_04.jpg
Price: $70,000 ENGINE: Engine Code: VQ32DETT Type: V6, aluminum block and heads, twin-turbo charger, intercooled Valvetrain: DOHC, four valves per cylinder, variable valve timing Displacement: 3197c Bore x Stroke: 95.5mm x 74.4mm Compression ratio: 8.5:1 Claimed Crank HP: 480 HP @ 7500 RPM Claimed Crank Torque: 500 lb-ft @ 4500 RPM Redline: 8500 RPM DRIVETRAIN: Layout: Longitudinal front engine, all-wheel drive Transmission: 7-speed sequential w/ paddle shift Differential: Electronic LSD center and rear, open front CHASSIS: Chassis code: BNC36 SUSPENSION: Front: Double wishbone, coil spring on shock, anti-roll bar Rear: Multi-link, inboard spring, anti-roll bar BRAKES: Front: 13.8-inch vented discs, Brembo 6-piston fixed calipers Rear: 13-inch solid discs, Brembo 4-piston fixed calipers Electronic driving aids/inhibitors: ATESSA-ETS, Super HICAS WHEELS AND TIRES: Wheels: 20 x 8.5-in. (F) 20 x 9.5-in. (R) forged aluminum Tires: 255/40R20 (F) 285/35R20 (R) Bridgestone RE050A Pole Position |
RE: 2008 Nissan GTR Specs released
i dont like it, it doesnt look like a trditional gtr(imo) the front end looks like they are trying to do it like the 350Z, but whatg is the saposed top-speed?
Sick... For 70 grand it should be one hell of a car.
top speed should be around 200mph
I don't care much for the looks, but those numbers make me drool![8D]
Awesome
To be completely honest......I like it a lot!
I dont like the body all that much but if I got to drive that beast everyday I think my point of view would change almost immediately.
The thing that stops it from being drop dead gorgeous is the front windshield brow being so high. A lower brow would have resulted in a more aggressive look. It still looks good overall though...
I think i filled the cup...
