EP3 vs. z6 crx your opinion
My buddy just got a 02 ep3 stock besides k&n filter and autozone muffler. I drive a 89 rex with z6 swap, I.H.E., blox intake mani, and stage 1 exedy clutch, weighed in at 1987lbs. Just wondering what you thought. 20 bucks on it just to make it fun.
what are the specs on the k20 in the ep3? weight? i would think the hatch, but i own a rex so im pulling for you lol. video that ish. idk if my b16 rex would outrun an ep3. maybe on top end?
edit:K20A3 Found In 2002-2005 Honda Civic Si (EP3) 2002-2005 Honda Civic SiR (EP3)(Canadian version of US Civic Si) 2002-2006 Acura RSX Displacement: 1,998 cc (121.9 cu in) Compression: 9.8:1 Power: 160 hp(120 kW) @ 6500 rpm(SAE net J1349 Rev 8/04) Torque: 140 lb·ft (190 N·m)* (191 N·m) @ 5000 rpm(SAE net J1349 Rev 8/04) Redline: 6700 rpm i-VTEC Engagement Window: 2200 rpm Seventh generation Si (EP3) Production 2002–05 Assembly Swindon, England Body style(s) 3-door hatchback (EP) Layout FF layout Engine(s) 2.0L 160 hp (119 kW) I4 Transmission(s) 5-speed close-ratio manual Wheelbase 101.2 in (256 cm) Length 165.7 in (420.6 cm) Width 66.7 in (167 cm) Height 56.7 in (142 cm) Curb weight 2,740 lb (1,240 kg) 160hp at 2740lbs??? that isnt good. maybe my rex will get a stock ep3. apparently, the ep3 mill had a sh!t head. 140 torques is nothing to brag about. hell, i say the z6 rex will get him, if the rex has been maintained right. sorry for all the info... |
Originally Posted by MBrent
(Post 746628)
OP, I trust this race will take part on a dedicated track and not on public roads? |
race and see who can crash into the tree first
I'm pretty sure the CRX will get it. EP3's, esp. stock, are sloooww. Worst Civic SI made IMO. No offensive to anyone who has one here, but just saying..
^ Agreed, friend of mine had one, never really raced against anyone but it def wasn't that impressive. The shifter is stupid as hell too.
no im not an idiot it will be a closed course our strip does 1/8th mile test-n-tunes year round.
I'm hoping your CRX wins. EF's were the best civic chassis ever made IMO but that's cause I own one. yes I'm bias. although i've always liked EG coupe's when done right. whats the HP and TQ on the z6?
D16Z6
VTEC Found in 1992-1995 Honda Civic Si 1992-1995 Honda Civic EX, EX-V 1992-1995 Honda Civic ESi (European Market) 1993-1995 Honda Del Sol Si (US) 1993-1995 Honda Del Sol ESi (European) Displacement : 1,590 cc (97 cu in) Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in) Rod Length : 137MM Rod/Stroke : 1.52 Compression : 9.2:1 Power : 125 hp (93.2 kW, 127 ps) @ 6600 rpm Torque : 101 ft·lb (14.7 kg/m, 144 Nm) @ 5200 rpm Volumetric Efficiency : 87.68% Redline : 7200 rpm Fuel Cut : 7411 rpm VTEC Switchover : 4800 rpm[3] Fuel Control : OBD-1 MPFI Head Code : P08 ECU Code : P28 and just for giggles, whats in my ef JDM B16A (First Generation) The first VTEC engine Note: All Honda Motor B16A engines are stamped 'B16A' (with no number after the "A" to identify version). Found in: 1988-1991 JDM Honda Integra RSi/XSi (DA6/DA8) 1989-1990 JDM Honda CRX SiR (EF8) 1989-1990 JDM Honda Civic SiR (EF9) Displacement: 1,595 cc (97.3 cu in) 1.6 liter Compression: 10.2:1 Bore: 81.0 mm (3.2 in) Stroke: 77.4 mm (3.0 in) Rod Length: 134 mm (5.3 in) Rod/stroke ratio: 1.745 Power: 160 PS (118 kW; 158 hp) @ 7,600 rpm & 15.5 kg·m (152 N·m; 112 ft·lbf) @ 7,000 rpm Redline: 8100 rpm Transmission: S1/J1/YS1 (4.4 final drive), Y1 (4.266 final drive, cable clutch, optional LSD) ECU code: PR3 (DA6/DA8/EF8), PW0 (EF8/EF9/DA6) OBD0 |
Originally Posted by LsVtec08
(Post 746647)
| All times are GMT -8. The time now is 12:45 AM. |
