02 Civic EX Gives No Fuel / Crank / No Start
Hello.
I'm checking in to get advice...
I have an 02 Civic which wouldn't start this morning.
I checked the fuel pressure line (on the back of the engine driver side, I think this was fuel. There was a dump valve, and when pressed gave zero pressure.)
It's 2 degrees outside, so I believe the fuel line has water in it and has frozen over.
If this is the case, what is the best way to defrost the line? I thought about putting a heater in the garage, but am taking the various loose fuels out of the room first as a safety precaution.
I've been considering the ignition coil and igniter as possible because of 132k mileage, however, with the fuel pressure at zero, I'm going to suspect the fuel first.
Suggestions?
Thanks in advance..
Suggestions?
Thanks in advance..
zerojett
Oct 18, 2011 03:01 PM
