05 Civic EX start problems
Old Feb 16, 2008 | 08:50 AM
morepower's Avatar
Default 05 Civic EX start problems
My Civic doesn't start like it use to, sometimes you must turn the key three to four times before it fires, mostly twice.
Its only got 25k, just wondering if these have a fuel filter that needs changing.
I probably need to go to the dealer, just trying to do the obvious, I'm going to shoot some injector cleaner, maybe try some hi octane gas for one tank.
Old Feb 16, 2008 | 10:34 AM
Default RE: 05 Civic EX start problems
Is the Check Engine Light ON?
After the engine starts does it run fine?
Remove the spark plugs and check whether they are fouled. If fouled, consider replacing both plugs and wires with OEM parts. Also remove the distributor cap and inspect the rotor and cap contacts for corrosion and wear. Replace if necessary.
David_S
Oct 24, 2013 10:06 AM
honvic
Oct 6, 2013 01:50 AM
pownstarz
Apr 19, 2010 12:30 PM
jaredjmoore89
Jan 1, 2008 09:51 AM
theycallmerickjames
Jul 9, 2006 02:22 AM
