HondaCivicForum.com
-   -   07 Civic EX Battery Discharge (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/07-civic-ex-battery-discharge-87531/)
alfred_dr Feb 6, 2011 04:04 AM
I have a problem with my civic battery. After not using the car for couple of days, the battery discharge, what makes this happen?
mk378 Feb 6, 2011 12:20 PM
Usually this is a worn out or faulty battery. Disconnect the battery while you're not using the car and then if it still doesn't start after you reconnect it, replace battery. If the battery doesn't run down while disconnected, check the car for things that don't turn off. The brake lights, light in the trunk, and aftermarket stereo equipment are common problems.
If you have a stock radio, you will need to enter the security code to make it work again after disconnecting the battery. Read the owner's manual and be sure you know the code before disconnecting.
alfred_dr Feb 10, 2011 07:09 AM
Thanks. Im going to the dealer to check the battery and see if the car have electrical problem. I appreciate your feedback and use it as a referrence too when the same problem happen again. :)
