1.5 to a 1.6
Old Dec 3, 2009 | 08:17 AM
civic94honda's Avatar
thats what i am now looking into is the mini me, im just out looking for a good d16z6 with a vtec valve still intact
Old Dec 3, 2009 | 08:21 AM
A complete 1.6 is of course somewhat more powerful than a mini-me, because it has more cc's. You still have a 1.5 liter engine with a mini-me.
Old Dec 12, 2009 | 04:15 PM
Flippinjig's Avatar
2X on the complete Z6. I've got a 1.5 (D15Z1) with a Z6 head. Runs good but not much power. Another option is to add a turbo to the mini-me (Z1 is low compression-good for turbo) but I don't know about the $$.
Old Dec 12, 2009 | 10:44 PM
wrong minime has more power than full vtec.
you dont have a minime the d15z1 is a vtec-e block they are 90 hp engines. now if you had a y7 or a b7 block with that head then you would have alot better power.
Old Dec 16, 2009 | 09:59 AM
Flippinjig's Avatar
Hmmm, I thought a minime was putting a different head on a motor than what came from factory.....Is it a vtec head on a non vtec motor??? Anyway are there advantages to having a Y7 or B7 minime over the stock z6??
Old Dec 16, 2009 | 10:47 AM
yes a mini me is putting a vtec head on a non vtec block, the advatage of doing this instead of just a full vtec motor is higher compression and more hp. also most of the time its cheaper to just put a head on the to swap a full motor
Old Dec 16, 2009 | 07:08 PM
so what do i want for the most power? now again i have the d15b7 non vtec block, do i want the 1.6 vtec(d16z6 head) or the 1.5 vtec head (what ever they ar called d15....)?
Old Dec 16, 2009 | 07:43 PM
keep your d15b7 block and put a d16z6 head and throttle body on it, also need the dizzy and ecu.
Old Dec 16, 2009 | 11:06 PM
and the dizzy is??? that the distributor?
Old Dec 17, 2009 | 12:22 AM
Flippinjig's Avatar
You're right. Dizzy is the distributor.
