1988crx with B16a wont start
Old Sep 6, 2008 | 11:46 AM
  #21
Originally Posted by Boost20
heres a pic of the camgears with some paintshop
The red arrows are of were the arrows are on the gear
Yeah, the mechanical timing is off, indicating that the belt slipped. Where was the crank positioned at this point?
Old Sep 6, 2008 | 11:51 AM
  #22
Boost20's Avatar
I believe its a tdc but im not sure.. turned it intill pleasure was coming out of the #1 spartk plug hole
Old Sep 6, 2008 | 11:55 AM
  #23
Use a long rod in the #1 spark plug hole to feel the top of the piston. Turn the crank until the rod is pushed up as far as it will go. That's true TDC. It should correspond to the single white mark on the front crank pulley.
Old Sep 6, 2008 | 11:56 AM
  #24
mk, based on the clearly misaligned cam gears, can't it already be concluded that the belt slipped?
Old Sep 6, 2008 | 12:02 PM
  #25
Yes that looks wrong to me too. In order to set it back right the crank must be known to be at TDC. Also I would suggest the OP install a new timing belt now rather than reusing one that has slipped.
Old Sep 6, 2008 | 12:09 PM
  #26
Boost20's Avatar
I now have it at tdc its the oppiste as in the pic the other cam gear is at the top and other is at like 12 o'clock. any recomundations on what belt to get brand wize ( if there is different brands ) just got the car a month ago so I dont know to much on honda's, all my other cars are chevy's. Is there a write up on how to install a new timing belt.. Thanks for all the the help guys
Old Sep 6, 2008 | 03:40 PM
  #27
I don't understand what you are saying. TDC1 for the cams on your Civic is different than the diagram? If so, how?
I would recommend you purchase a Honda timing belt. Look here:
http://www.hondaautomotiveparts.com/
Download the 88-90 Civic manual at the link in my signature.
Old Sep 6, 2008 | 04:08 PM
  #28
Boost20's Avatar
No sorry. what I ment was that I didnt have it at tdc before because I didnt notice the notch out of the crank puly.. so it now sitting at tdc the cam gears are not in the same position as they were in the picture, the cam closest to the firewall is at 12 o'clock and the other cam gear closest to the front of the car the arrow is pointing up.. still not in time but atleast know I know whats wrong... I'll get a belt next week and try to install it.. Thanks alot for all the help
David_S
Oct 24, 2013 10:06 AM
bmelloh
May 16, 2009 08:01 PM
cadman421
EK Swaps
May 11, 2007 12:47 AM
AndyI
Oct 6, 2004 09:36 AM
89 pos
Jun 25, 2004 05:35 PM
