HondaCivicForum.com
-   -   1989 Civic stalls after warm up while driving (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/1989-civic-stalls-after-warm-up-while-driving-99132/)
Freddybob4244 03-05-2019 06:20 PM
Hey everyone, this car has been a journey.
It's a 1989 Civic LX with a 1.5L Dual Point, standard trans. It runs good and drives fine until it warms up, and then it dies when the RPMs drop to idle. It stumbles a little before it shuts down, and you can smell raw fuel, so I think its flooding out, I just can't figure out why. It restarts just fine after a minute or so, with the throttle held open like a flood clear on a modern car. I'm out of ideas here, and I hate to keep shotgunning parts at it, so any help is much appreciated. See below for a list of parts and other work that I have done over the last few months.
First off, the car wasn't running when I got it, and by the looks of it, it hadn't been running for a long time. I had to do quite a bit of work just to get it to start, ill give a brief run-down of the new parts and a quick reason why it was replaced:
Let me give you a brief background of everything that has been done so far:
The list of new parts:
- Rebuilt Brake Master Cylinder
- New Brake Booster
- Distributor - Broken ignitor
- Starter - Solenoid failure
- Main Relay - No voltage sent to fuel pump
- Fuel Pump - Rusted and falling apart, INOP with voltage applied
- Fuel Filter - Totally clogged from bad gas (cleaned the tank too during pump change)
- Vacuum Lines - Dry rotted
- Alternator - Diode blown (previous owner jump start - wasn't charging)
- Spark Plugs - Old
- Spark Plug Wires - Old
- EACV/IACV - No idle adjustment under load/surging idle
- Throttle Body - Leaking shaft bushing & vacuum pots (came with rebuilt injectors)
- Fuel Pressure Regulator (bad diaphragm)
For the rest of the other work that I've done:
- Checked timing, its dead on.
- Valve adjustment
- Both coolant temp sensors (thought maybe stuck in open loop?). I kept getting conflicting info, so I just did both of them.
- Charged A/C system with R12 (unrelated, but thought I would include it).
