HondaCivicForum.com
-   -   1995 honda civic lx bogs down on hills (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/1995-honda-civic-lx-bogs-down-hills-94573/)
Devinmockk Dec 4, 2012 05:08 PM
So i just got this honda i had to drive it home from colville and there are some hills, so every time i hit a hill id press the gas and then......... nothing, i downshift and still it boggs and slows way down i even got down to 2nd gear with the petal to the floor and still nothing any ideas?
lovespeed Dec 12, 2012 11:52 AM
It only does it going uphill?
Devinmockk Dec 13, 2012 11:35 AM
Yes but i think it might be that my catalytic converter is clogged up from being driven for a couple miles with 8qts. of oil in it so i think if i changed that it would work better.
mk378 Dec 13, 2012 12:03 PM
Check the spark timing first. Having it retarded will really kill performance. Timing can change suddenly if the timing belt skips a tooth. If that has happened, you should put on a new belt immediately to avoid having it fail completely.
lovespeed Dec 13, 2012 08:49 PM
8 quarts of oil is wayyyyyyy to much for your car that could b the issue, how many miles are on the car?
Devinmockk Dec 14, 2012 11:15 AM
i checked the timing and its perfect all around and i have no idea how many miles are on it the gauge cluster is from a different car but i think the engine has around 70k tho And yes for an engine that has a max of 4.5 qts the dipsh*t put more oil in it then drove the sh*t out of it and had it overheat so i have no idea what to do other then that.
mk378 Dec 14, 2012 01:25 PM
Driven overheated you should check the compression.
Oil change on that engine is 3.75 quarts-- including a new filter.
Devinmockk Dec 15, 2012 06:53 AM
yeah and i traded a perfectly good running car for this thing and the dude had no idea what he was doing. last thing i need is having to do a rebuild.
