1998 Civic rough idle
you can start with basic maintance if you are not sure it has been done.
spark plugs and spark plug wires. clean IACV. maye some fuel system cleaner. reset ECU. from there it might be easier to figure out if you have a serious problem or not.
Adjust the valves. Follow the procedure exactly.
As the engine heats up, valve clearance decreases, which can cause loss of compression if a valve is set too tight to close completely.
You can check if there is a problem isolated to one cylinder by disconnecting the fuel injectors one at a time with the engine idling. Do not disconnect spark plug wires with the engine running! That is prone to blow out the coil.
oidale
Jun 26, 2010 06:27 PM
Stumasters
Jan 20, 2008 12:58 PM
brinriha
Jun 14, 2007 10:55 PM
