1998 honda civic ex automatic I NEED HELP
im a owner of a automatic 1998 honda civic. it has 90k miles. i bought it when it ran but neeed body work. i took the motor out and fixed everything. after i installed the motor i noticed that the check engine light is on. i took the car out for a spin, it did not feel right at all. It feels like the tranny shifts hard, and the car studders some times. i went to shucks and got the code reader. it gave me codes, P0325, P0700, P0720. i replaces the knock sensor (p0325). and reset the computer. then the light came back on and it gave me the same codes! including the knock. so what are your thaughts on this? any help will be much appreciative! Also the D4 light on the dash is blinking.
What did you fixed when you remove the engine? The body or the engine? You have to double check that all the sensors are hooked properly and make sure that the engine harness was not damaged during the removal/installation process.
i had to weld in new frame rails. i am almost one hundred percent sure wevery thing is plugged in. any spacific ones??
stalin11
May 4, 2011 12:34 PM
stalin11
Apr 30, 2011 01:25 PM
stalin11
Mar 20, 2011 01:08 PM
domex
Mar 25, 2007 11:54 PM
