HondaCivicForum.com
-   -   2002 Civic Thermal Protector help. (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/2002-civic-thermal-protector-help-89248/)
andybess22 Jun 8, 2011 07:45 PM
Hey everyone I have a 2002 Civic and I am changing my thermal protector and I have a question. To make a long story short me and my friends were on a cross country trip in the middle of summer when my AC stopped working. I figured out it was the thermal protector. So what I did was just the end connectors off the thermal protector and I think the other end goes to the AC button in the car when it is pushed it tells the compressor to turn on. Is that correct? But i guess my real question is I want to fix it the right way I ordered the thermal protector but i lost the end that plugs into it. Does anyone know if I can order that connector end? I tried calling the dealer but the guy didn't know what I was talking about. Thank You!
mk378 Jun 8, 2011 07:52 PM
Thermal protector is in series with either the clutch coil (if there's one big wire to compressor) or the pressure switch (if thermal protector has its own 2-wire plug with small wires.)
andybess22 Jun 8, 2011 07:54 PM
When i cut the connector of the thermal protector it had 3 wires. 2 smaller wires and one bigger (fatter) wire.
mk378 Jun 9, 2011 03:24 AM
That's the plug for the whole compressor then. Two small wires are the protector and the fat wire goes to the clutch.
andybess22 Jun 9, 2011 01:41 PM
So if i buy the thermal protector set part number 38908-PLM-A11 that goes into the compressor right? I need that and then whatever plugs into that do you know where I can get that?
mk378 Jun 9, 2011 02:15 PM
The part includes the plug for the compressor side. The plug on the car side is part of the whole harness. If you need that you could cut it out of a junked car and splice it into your car.
andybess22 Jun 9, 2011 04:56 PM
So if I order that part it bolts to the compressor and that will take car of the compressor side correct? And I will need to get the connector that plugs into that plug. And that connector basically runs into the car and is controlled by the A/C button am I understanding that correctly? If that is correct thats what I was thinking trying to find a junked car and cutting it off. Thank You
neons1 Jul 5, 2012 06:49 AM
ac thermal protector
hi after you change the thermal protector is your ac copressor clutch work?
also did you change the shim for ac clutch? also this thermal protector has 3 wires 1 big fat and 1 medium and 1 small? i know medium and small wires connect to ac compressor how about the big fat long wire is this connect to fan driver side?
mcquin35 Jul 10, 2012 07:42 PM
if you are looking for the connector that join the thermo on comp to wire on rad support. they are the same on older civics , just reversed. gray one pin. I bypassed my thermo by using a male end from 96 civic brake fluid cap and gray one pin from same car.
