2002 EX, Trunk Leaking Water
Old Oct 11, 2009 | 06:28 AM
DeanHensler's Avatar
Default 2002 EX, Trunk Leaking Water
My 2002 EX is leaking water into the trunk. I've inspected the weather stripping and it all looks great. I've noticed when I shut the truck, it shuts securely, but has a little bit of spring to it and isn't staying all the way shut. If I push down on it, it has some play. Is that adjustable in any way?
It appears the latch isn't holding the truck all the way down against the weather stripping and when it rains the water is getting between the trunk lid and the weather stripping.
Old Oct 11, 2009 | 10:30 AM
You can play around with the alignment of the latch striker on the underside of the trunk lid
Old Oct 11, 2009 | 12:19 PM
AOL.COM's Avatar
an easy way to find a leak in a trunk , is to give a friend a flashlight then shove him in the trunk & shut it, then get a garden hose & spray around the trunk starting at the bottom & work your way up, when he screams .....you found your leak
dont laugh, my ex boss did this to me a few times .... it works
rxfish
Nov 28, 2010 05:47 PM
lbiasotto
Oct 20, 2007 06:59 AM
cnote
Apr 16, 2006 04:31 PM
mill$civic
Dec 13, 2005 05:36 PM
