Timing belt and head removal
Old 02-05-2013, 05:36 PM
jockellis's Avatar
Default Timing belt and head removal
Do both the timing covers HAVE to come off to loosen the belt so the head may be removed or can you just loosen the bolt from the outside? This has probably been answered many times but on all my car forums I have never been able to wade through the numerous threads to find the info I need.
Old 02-05-2013, 05:54 PM
There is a plug in the lower cover for access to the tensioner bolt. Remove upper cover, remove plug, loosen bolt and pull slack in the timing belt. While it is slack tighten the tensioner bolt so it stays slack.
Before doing this, set the engine to TDC1 and confirm the crank and cam marks align, so you know the marks are OK and you can get it back in time upon reassembly.
To set tension, have the tensioner bolt just loose so the spring pulls the tensioner against the belt. Turn the crank counterclockwise by hand to pull out the slack on the front side of the belt. Tighten tensioner SECURELY. Never use the starter while the tensioner bolt is loose, turn engine by hand only. Also before starting double check timing and turn crank two complete revolutions by hand to make sure nothing crashes.
smackpower
01-13-2024 01:42 AM
Kyle700
09-18-2014 07:44 PM
chuzie
03-06-2013 02:54 PM
pippo
01-26-2010 02:40 PM
2DHX
04-28-2006 05:58 AM
Quick Reply: Timing belt and head removal
