larrymike |
07-06-2012 05:28 AM |
2004 civic lx drivetrain noise
120K on the odometer.. Only once while going from park to drive, or drive to reverse, or reverse to drive or park to reverse, I get a "click,click" from both sides, I think near the steering knuckle. Wheel bearings sound fine. No CV joint clunk while turning, Does not matter if the brakes are on. It only happens once, that is, if you go from reverse to drive, you get the click, and it is louder if you stab the gas harder.. but then the noise is done until you shift into reverse and then stab the gas. Then it "clicks back" and is done unit you change to forward again. I've never had this with any other car. Trans shop looked at it, said all was good with the trans, and motor mounts are fine, wouldn't be able to know what it was unless they took it apart. I am hoping someone else has had this.. Thoughts? Thanks, Mike.
