HondaCivicForum.com
-   -   2006 LX Stuck Window (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/2006-lx-stuck-window-81056/)
Schwizzle Feb 19, 2010 07:52 AM
My rear passenger's side window is stuck in the up position. I rarely roll it down, so I have no idea how long it's been stuck. The only thing I'm sure ofis that it's not just a problem with my window switch since neither the driver's nor the rear passenger's buttons work.
I don't know if the tutorial already up on slow moving windows applies since the window doesn't move at all. Also, my Civic is a much newer body style than the one in the pictures i nthe tutorial (2006 LX 4-dr).
Anyone have suggestions? I'm sure I can do the work myself with instructions, but haven't ever really dealt with maintenance on a car before.
mk378 Feb 19, 2010 12:35 PM
I'd start by taking the door panel off and see if power reaches the motor when the button is pressed. If it does the window is jammed or the motor is bad. If not there is an electrical problem somewhere else. I think that the wires in the driver's door can break and disable both switches but would need a diagram of the 2006 to be sure.
