Oil leak?
Old 05-18-2014, 04:50 PM
justinksg's Avatar
Default Oil leak?
Hey guys I've viewed the forum here for a while, just got around to making an account and hope to get active on here. I bought a 98 civic ex (ej8) with a d16y8 motor about a month ago with about 165k bone stock.
I noticed the oil was a little low when I got it so I topped it off and didn't check it until the other day, to my shock it was extremely low So I looked around and have managed to find the place it leaks? There's no oil spots in the driveway but it's clearly around the left side of the motor. It looks like it's coming from where the distributor meets the engine? Or it's the head gasket (really hoping this isn't the case). The engine doesn't over heat or even come close to it. Doesn't burn any oil that I can tell. Oil looks clean under cap. So here's some pictures, if anyone could tell me anything I'd greatly appreciate it!
Old 05-18-2014, 04:52 PM
justinksg's Avatar
The way it looks stock if anyone's interested.
Old 05-19-2014, 01:30 PM
The pictures are of the area near the VTEC solenoid. If the gasket is blown it could be leaking oil, but in a way that only happens when you drive hard enough to engage the VTEC. Then it can leak a lot, since the oil in the solenoid is under pressure.
Old 05-19-2014, 06:35 PM
droopy128's Avatar
Looks like you should change your distributor o-ring.
Old 05-19-2014, 07:33 PM
justinksg's Avatar
I dont think it's the vtec solonoid, it seems fine around there. I just ordered a distributor o ring today ill clean the bay and put that in and see if it fixes it, thanks.
theRDRman
11-28-2011 04:18 PM
shadow_93
12-28-2009 11:26 AM
oilltd
06-10-2008 04:06 PM
mokijo2
12-27-2007 12:11 AM
Quick Reply: Oil leak?
