2009 civic dashboard trouble
Old Sep 29, 2013 | 02:11 AM
clive18's Avatar
Default 2009 civic dashboard trouble
Hi.
My dashboard cluster suddenly went blank. Both the speed section with the fuel gauge & temperature section, as well as the rev counter and odometer all being blank. The only lights on, are the airbag, abs and park brake lights remain on. This is even when the park brake is released.
The car seemed to be working ok, the radio works, but the aircon seems to be affected too (even though the aircon controls light up, and the fan works)
I checked all the fuses , and they are fine.
I tried to do the check with holding the reset button and switching the lights on and off, but could not get the self test to work at all.
The backlight to the dashboard refused to turn off when the ignition was turned off, so now I have a flat battery as well.
Any pointers would be really appreciated.
Thanks in advance
Clive
Old Sep 30, 2013 | 12:01 PM
CivicDuty01's Avatar
I had the same problem happen with a vehicle (not a Civic, but same premise) and had to replace the whole cluster...
It's not too expensive
2009 Honda Civic Parts - OEM Honda Parts Online
I don't know why some fault out so quickly.
Old Oct 1, 2013 | 09:18 AM
clive18's Avatar
Default Sorted
Hi Civic Duty
Thanks for the reply.
What happened is that my battery ended up getting drained, and I called the AA to help jump start the car.
Turned out that the battery cable had a bad connection, and this was causing the voltage to drop, which affected the instrumentation. I was almost resigning myself to buying a new MCU/fuse box which is what controls the dashboard.
So, with my MCU effectively being reset, and my battery back on its cable properly, I am a happy driver once again.
Hopefully this post will help someone with a similar issue.
regards
Clive
CatsnotCars
Jan 28, 2015 12:24 PM
JCmods
Mar 20, 2009 12:03 PM
garynaz
Aug 7, 2007 08:51 PM
garynaz
Aug 7, 2007 03:38 PM
luckycat15
Mar 7, 2005 08:28 PM
