520T Battery Backup Module HELP?
1998 Honda Civic EX Sedan 5-Speed
Viper 5002 alarm system
Everything is ready for the install starting tomorrow morning. Looking over my notes there is an area of confusion.
Is this correct?
RED .. (15A fuse 12” from power source) to 12V Constant [18 gauge wire]
GRAY (+) 12V Output - to Viper (+) 12V Constant (should there be a 15A inline fuse here?)
BLACK .. GROUND to Chassis
BLUE (-) Output to Control Module - tap H2/2 GREY (-) Hood Pin Input, Zone 6 (22 gauge) (Is this correct? Isolate this?)
On CauseForAlarm I read "...Cut the alarm's red power wire an inch before the fuse and connect it to the backup module's gray wire." Why do this if the Backup Battery Module's GRAY wire connects here anyway, and a fuse is called for in Backup Battery Module's instructions??
Is it OK to extend the Antenna wires?? I'm mounting it in the center of the windshield, and wire will not reach the brain.
Is this correct?
pinto900
Nov 25, 2007 06:20 AM
cowsgonemadd3
Apr 5, 2007 01:03 AM
rubstr00
Feb 16, 2006 12:00 PM
